I recently switched my workstation and render nodes to vray 3.
I first made some basic tests, creating simple scenes, first only on my workstation, then with the render nodes and everything worked fine.
Then I wanted to try with some recent projects made with vray 2.x. They render fine on my workstation, by always fail in distributed rendering mode. The scenario is always the same :
- render host is added
- scene transferred to renderhost
- warning : render host is not responding.
I attached a screen capture of the V-Rcay messages window.
I noticed that if I make a new scene and merge the old one inside, then it will render fine in DR. So I guess the objects in the scene are OK but some parameter in the file itself is causing some trouble with the new version of V-Ray. Any clues on what may be the cause ?
Thank you very much.
