Heya Folks!
I'm using deadline and they've got a handy system to manage vray DR render where it'll open and close the spawner at the start and end of each job so if it crashes it can restart it, and max won't have to remain permanently open in case you want to install any bits. My issue is that when I use DR through deadline it's trying to use port 20212 for all the slaves instead of 20204. I'm not sure if 20212 is the old 2.4x port and I'm able to manually edit each server when I use DR the normal way to use 20204 but is it possible edit the port that vray 3 listens on or the default port that vray will try to use as you add in a new DR server?
Cheers!
John
Cheers!
John
