If you are using a Global Override material, the AA for the VRayObjectID render element doesn't work. Also, can someone explain to me why AA isn't on by default for that?
It is a problem with the sampler. The V-Ray Toon line color is set to "black" which forces the sampler to use the minimum number of samples in that area. Something that you could do in this case is to:
> Decrease the Color threshold parameter
or
> Increase the AA Min Subdivs
