3d max crash after install nightlie
    Dear programmers Chaosgroup.
    After making a very limited research on my low technical knowledge, I could make any version higher than 3.00.08, could be executed.
    Yesterday ... when I saw that launched the new version and try to install it, thinking that the problem would be solved.
    It was not so and my frustration was great ... then try to sought a solution ... something ramshackle and without any kind of wisdom. Minutes passed and thought ....
    which if I make an installation on earlier without uninstalling the old version?
    This done, 3d max vray ran perfectly and remained installed. The version was correct and everything ok. Then told me ....
    -and if I uninstall everything and go back to re-install the new version? .... Once completed all remained working wonderfully.
    I wanted to share this story to another user with a similar problem could have a methodology that leads to success.
    Best Regards
    Andres Ahumada Maceratta
      Good to know that you got things working eventually - I'm still puzzled as to what was causing it to crash.
