Yea, Spawner is broken again (sarcasm)
  • #31
    Nooooo Me toooo COME ON!
    buaaaaa
    • #32
      Originally posted by Pixelcon View Post
      I still get the slave not responding message in the vraylog window. Like you say it could be a multitude of issues tho not specifically relating to sp3...
      Well, at least you can easily revert to a previous V-Ray build to see if it works.
      • #33
        What build its ok?
        • #34
          This can help
          http://knowledge.autodesk.com/sites/...me.htm#Install
          UnInstall SP3
          • #35
            Hi Vlado
            this build, vray_adv_31501_max2015_x64_25424 works fine for me.
            • #36
              And the one immediately after it breaks?
              • #37
                You mean I run after having tried to build that would be broken?
                I install the build nightlie above the 3.10.02.
                The build 3.10.02 DR caused me problems completely. Do not connect any DR.
                Once you install the nightlie all connect without problems.
                • #38
                  I have the same problem. I just installed Max 2015 and all service packs + extensions. Backburner ist working but DR is not.
                  Which build should I choose as soon I have access to the nightlies?
                  Bye Jan
                  • #39
                    The latest one.
                    • #40
                      I installed it on three machines so far and it is working perfectly.
                      • #41
                        Sorry my BAD!!
                        Edited post
                        • #42
                          Any idea when this will be released officially?
                          "It's the rebels sir....They're here..."
                          • #43
                            I second that question ("Any idea when this will be released officially?")
                            I tried to contact support to have access to the nightlies - but no one answered and I need it very badly, deadlines are approaching
                            • #44
                              I found your ticket in our system and will reply to it right away.
                              Tashko Zashev | chaos.com
                              • #45
                                Is there a patch for VRay 2.0 also to fix this SP3 issue?
                                Kind Regards,
                                Morne
