Light Not Lighting Scene
  • Light Not Lighting Scene
    Hello,
    In my scene I use a VRay dome light for the main scene lighting, but within an enclosed area I need to create some additional lighting. I have been able to do this by using a standard omni light, but I cannot get the additional lighting to work with using either a VRay sphere or 2nd dome light. Each time it renders as if it is turned off. What am I missing here?
    thx
    What kind of camera are you using? If its the V-Ray physical camera I would start by lowering the shutter speed and see if that helps. Can you post a screenshot of the light and camera settings?
    Cheers,
    -dave
    ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
      I'm just using the standard 3ds max camera.
Name:	dark light.jpg
        try decrease your shadow bias see whether it help or not
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
          Originally posted by leejk View Post
          Hello,
          thx
          DomeLight won't illuminate the enclosed scene unless the enclosed objects is excluded from shadow casting.
          V-Ray lights placed inside the enclosed volume should affect the rendering however.
          Would it be possible to attach a simplified version of the scene for investigation?
            I was able to figure this out finally... it appears that something went wrong when the light was created. I think it was originally created as a plane light then later switched to sphere. I deleted it and re-created the light and it's working as expected.
              Glad to hear you sorted it out.
              Let us know if it happens again.
