Light Not Lighting Scene
  • Light Not Lighting Scene
    In my scene I use a VRay dome light for the main scene lighting, but within an enclosed area I need to create some additional lighting. I have been able to do this by using a standard omni light, but I cannot get the additional lighting to work with using either a VRay sphere or 2nd dome light. Each time it renders as if it is turned off. What am I missing here?
    thx
    What kind of camera are you using? If its the V-Ray physical camera I would start by lowering the shutter speed and see if that helps. Can you post a screenshot of the light and camera settings?
    Cheers,
    -dave
      I'm just using the standard 3ds max camera.
Name:	dark light.jpg
        try decrease your shadow bias see whether it help or not
        Jackie Teh
        3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
          Originally posted by leejk View Post
          thx
          DomeLight won't illuminate the enclosed scene unless the enclosed objects is excluded from shadow casting.
          V-Ray lights placed inside the enclosed volume should affect the rendering however.
          Would it be possible to attach a simplified version of the scene for investigation?
            I was able to figure this out finally... it appears that something went wrong when the light was created. I think it was originally created as a plane light then later switched to sphere. I deleted it and re-created the light and it's working as expected.
              Glad to hear you sorted it out.
              Let us know if it happens again.
