Odd Caustics pattern using displacement and phoenix ocean map
  • Odd Caustics pattern using displacement and phoenix ocean map
    When I use vray disp + phoenix ocean map + caustics I get a weird caustics pattern. Which doesn't seem like its supposed to happen. Given how "smooth" the water plane looks.
    If I use a noise modifier I don't get this pattern at all even with a more rough surface look.
    *edit* sorry I forgot to mention I'm using a standard spotlight to create the caustics. The large vray light + vray sphere light are not generating any caustics.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    Would it be possible to attach that scene for investigation?
    Let us also know what V-Ray/Phoenix FD/3DSMax version you are using.
      Sure thing. I sent you an email to "support@chaosgroup.com" with all the details.
      Cheers,
      Oliver
        It seems that the Edge Length value is too high by default for this setup.
        Lower values produce better results:
          Big thanks for finding a solution! Will try it out as soon as possible.
          Cheers,
          Oliver
