VRayRT - Helix with a bend modifier
  • VRayRT - Helix with a bend modifier
    RT doesn't seem to render a helix with a bend modifier on it.
    It will render a helix (viewport and renderer enabled etc.) without the modifier, it will render a line with a bend modifier.
    However, this may be a max thing, because if you collapse the bend modifier and then convert the bent helix spline into a editable poly it disappears, which might explain the RT result.
    Is this a known problem?
    Simon
    I need a new signature
    Max2017.1 | Vray 3.70.01| win11
    ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
    We weren't aware of the issue. Now it's in our bug tracking system.
    Thank you for your feedback.
      A simple workaround is to apply Edit Poly modifier directly on Helix and then apply the Bend and any other modifier you need. This will do it for RT.
      Best regards!
      Margarita Stoeva | chaos.com
      Chaos QA (V-Ray for 3ds Max)
        You can also put a Renderable spline modifier on top of the bend, which should also work. This looks like a bug in 3ds Max though.
