Steps to reproduce:
1) New Scene
2) Create a VRayPhysicalCamera
3) Adjust Camera parameters so that horizontal and vertical shift is any value other than zero
3) Go to frame 100
4) enable autokey
5) change horizontal and vertical shift parameters (and also any P/R/S)
Expected behaviour:
Autokey automatically creates a key at frame 0 and 100 with the correct values
Observed behaviour:
Max creates the keys for shifts at frame 1 instead of frame zero. Key for transformations are correctly created at frame 0
If trying to move the shift keys from frame 1 to frame 0 they reset to value 0 at frame 0 and not to the set values of reproduction step 3.
Edit: Apparently its only in my scene where it doesnt get properly adjusted when the keyframe is moved to frame 0.
Nonetheless it gets created at 1.
1) New Scene
3) Go to frame 100
4) enable autokey
Expected behaviour:
Observed behaviour:
