Phoenixocean texture bug
  • Phoenixocean texture bug
    I don't think I am doing anything wrong but when I am close up to the plane using vray displacement with the phoenixocean displacement shader I can see the subdivision lines.
    Regards
    Steve
    My Portfolio
    That's very interesting.
    Would it be possible to attach that scene for investigation?
      Here you go. It occurs for the first 3-4 frames. I am close to the ocean plane but it is still quite odd. Can you let me know when you have downloaded it please.
      Regards
      Steve
      My Portfolio
        What is the exact version/service pack of V-Ray/3DSMax and OS that you are using.
        I've just rendered the scene with the latest versions of V-Ray and Phoenix but I couldn't reproduce the issue.
        Here how frame 4 looks like in our environment:
          Os: win 7 64bit
          3dsmax 2014 - SP3
          Vray: 3.10.03
          Phoenix: 2.2.0 - not sure if this is relevant.
          Did you try frame 0 ? It definitely does it for me there.
          Regards
          Steve
          My Portfolio
            seems like edge length related issue.
            just for curiosity, why you are using vray displacement? some issues in our ocean rendering perhaps? if so, tell us to fix them
            ______________________________________________
            VRScans developer
              I'm assuming you mean you can create the phoenix ocean from directly within Phoenix simulator ? I thin I tried this but I cannot remember why I used this other method. May have been render times or something.
              Yes, I did increase edge length to reduce render times.
              I'm intrigued now about the other method for setting up the infinite ocean ?!
              Regards
              Steve
              My Portfolio
                just create coarse simulator, enable liquids, initial fill up, start sim for 2-3 frames and set the input on direct frame. this will provide you infinite ocean even if the simulator is outside the view
                VRScans developer
                  and this will animate ? I'll give this a go. Cheers
                  Regards
                  Steve
                  My Portfolio
                    yes it will. the displacement state is based on the rendered frame index, not on the cache index. you can have only single frame rendered in the entire animation, the simulator's content will be not animated, but the displacement will be.
                    VRScans developer
                      Thanks. This seems to be working well. The only issue I have is that the simulation area seems to be slightly sunk compared to the rest of the ocean.
                      Regards
                      Steve
                      My Portfolio
                        I have one more problem. I've calculated about 5 frames at the beginning. The direct frame index is set to 5 as in the viewport it looks like that is when the fill up is complete. Thing is that the ocean will not render past frame 5.
                        Regards
                        Steve
                        My Portfolio
                          It seems load nearest possible sorts this.
                          Regards
                          Steve
                          My Portfolio
                            why you render the simulator at all? put it outside the visible area, you need it just to generate the extension
                            VRScans developer
                            • #15
                              Yep, I just realised that one myself Thanks for all the help
                              Regards
                              Steve
                              My Portfolio
