Amb. occlusion & Render To Texture
  • Amb. occlusion & Render To Texture
    Turning on Amb. occlusion in the Global illumination rollout, causes weird issues with Render To Texture. I didn't get a screenshot, but it was causing a strange patterning over the UV's. I just turned it off and now the object is baking correctly.
    I could setup a test scene to double check and share if needed.
    Brendan Coyle | www.brendancoyle.com
    Not really surprising because the gi AO is based on what your screen sees I believe. What you can do is use a vraylight material with a dirt in it and that'll bake fine.
      Oh good point. A dirt map will work for this case since I'm using a single vray mat across the scene.
      Thanks
