Weird texture where two geometry's intersect
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
Originally posted by Streetwise View PostI have a particular render where there's a funky grey texture where the feet of an object touch the floor. Not sure if it's more of an issue with reflection, or where the two geometry's touch? I do this sort of thing all the time and have never run into it before.
[ATTACH=CONFIG]23326[/ATTACH]
David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
By any chance, is there a VRayDirt map applied to the floor? If so, add the furniture to its Result Affect list.
Edit: "consider same object only" would do even better if that's the case.Last edited by Margarita.Stoeva; 16-03-2015, 08:31 AM.Margarita Stoeva | chaos.com
Chaos QA (V-Ray for 3ds Max)
Originally posted by Margarita.Stoeva View PostBy any chance, is there a VRayDirt map applied to the floor? If so, add the furniture to its Result Affect list.
Edit: "consider same object only" would do even better if that's the case.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
