Weird texture where two geometry's intersect
  • Weird texture where two geometry's intersect
    I have a particular render where there's a funky grey texture where the feet of an object touch the floor. Not sure if it's more of an issue with reflection, or where the two geometry's touch? I do this sort of thing all the time and have never run into it before.
Name:	Screen Shot 2015-03-16 at 10.07.53 AM.png
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    [ATTACH=CONFIG]23326[/ATTACH]
    Have you checked the render elements to see in which one it occurs?
    A.
    www.digitaltwins.be
      vrayShadows and vrayLighting is the only place I see it. I have a single HDRI dome light set to 200 Subdivs. I don't see any place to tweak Shadow subdivs. AA looks really good btw.
Name:	Screen Shot 2015-03-16 at 10.34.03 AM.png
Name:	Screen Shot 2015-03-16 at 10.40.19 AM.png
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        By any chance, is there a VRayDirt map applied to the floor? If so, add the furniture to its Result Affect list.
        Edit: "consider same object only" would do even better if that's the case.
        Margarita Stoeva | chaos.com
        Chaos QA (V-Ray for 3ds Max)
          Why, yes it does! Thank you so much. I'll give it a shot!
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
