Vray clippper wrong lighting result
  • Vray clippper wrong lighting result
    Left=clipper / right = camera clipping
    Using the 3.08 version, the clipper problem regarding the light is still present.
    The rendering look significantly different with or without clippers.
    The camera clipping return a darker result.
    Hope it can be fixed quickly because it is really annoying.
    Can you try with "Affect Lights" off in VRayClipper ? If this doesn't help, please send me a scene at peter.matanov@chaosgroup.com
    Peter Matanov
    Chaos
      the scene have been sent for debugging.
        There is something strange indeed, will log this in our bug tracking system. Thanks for the report !
        Peter Matanov
        Chaos
          are the normals correct? if any of the geometry doesn't have a thickness and has the wrong normals direction it will cause issues
          Brendan Coyle | www.brendancoyle.com
            Thanks,
            Are plane a geometry that need thickness as well?
              Either thickness or just needs to have the normals facing inward into the room. I had a file where the walls were extruded lines that had their normals flipped, and it caused lighting issues within the space when using the clipper.
