Glass Issues
  • Glass Issues
    I'm having an issue with some glass partitions. The office "dividers" are a frosted material, and the long glass wall is a clear material. I need to change the v-ray properties of each (Ie. visible in reflections, visible in refractions) but am unsure which to use for which objects. In this example, anywhere you see frosted glass, it's because you're looking through an open door into that office. What I don't understand though is why the frosted glass doesn't form an entire wall, but gets eliminated anywhere there's clear glass over it. The three desks you're seeing are not reflections, but the actual office spaces. It's almost like the clear glass cancels out anything that's behind it if that makes sense.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2023.3 Update
    V-Ray GPU 6 Update 1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Hi David,
    I assume that the frosted glass objects are excluded from the glass refractions. Could you check this?
    Otherwise it will be good to check the scene file and investigate further.
    Tashko Zashev | chaos.com
      Originally posted by tashko.zashev View Post
      Hi David,
      Actually, "Visible in refractions" is turned on for both the frosted and clear materials.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Can you post part of the scene to see the entire setup?
