HDRI problem
  • HDRI problem
    Hi all, i have a Vray dome light in my scene, but client dont like the hdri image as background, so i create a plane outside of my window and attached a background image(jpeg) given by my client, but when i render the scene, i discover that the background plane has block the vraydome light, what should i do avoid this?
    i am using 3ds max 2014 + vray 2.40.04
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    anyone help??
    Jackie Teh
      Make the plane to not cast shadows, and also make it invisible to GI?
        I have make the plane (in object properties, i untick receive shadows, cast shadows.), (in vrayobject properties, i untick generate gi, receive gi and visible gi)
        is there anything i have miss out?
        Jackie Teh
          That seems about right. Can you post a scene with just the plane, some geometry and the dome light to check what may be wrong?
            can, mr vlador, where should i post?
            Jackie Teh
              Hi Mr Vlado, i have send the file to vlado@chaosgroup.com, please check, thank you.
              Jackie Teh
                Hi Jackie,
                I've rendered the scene that you sent to Vlado with the BG object (background plane) and without it but didn't find any difference in the lighting. Can you send me a simple scene that reproduces the problem at peter.matanov@chaosgroup.com? Because the one you sent is missing textures so I had to override the textured materials and the HDRI that was in the Dome light.
                Peter Matanov
                Chaos
                  Peter, try rendering with V-Ray 2.40; it worked fine for me in V-Ray 3 too.
                    I exclude from dome light and my outside window plane is a V-Ray light material
                    Bobby Parker
                    www.bobby-parker.com
                    e-mail: info@bobby-parker.com
                    phone: 2188206812
                    My current hardware setup:
                    • Ryzen 9 5900x CPU
                    • 128gb Vengeance RGB Pro RAM
                    • NVIDIA GeForce RTX 4090 X2
                    • ​Windows 11 Pro
                      Tried both 3.1 and 2.40.04 - the renders are identical with and without the BG plane.
                      Peter Matanov
                      Chaos
                        Hi thank you for reply,
                        i attached two crop image to show what is my problem,
                        the lighting of the with back plane one is darker if compare to the without back plane one, right??
                        Once again, sorry about my poor english.
Name:	hdri problem01.jpg
ID:	855852Click image for larger version
Name:	hdri problem.jpg
                        Jackie Teh
                          Isn't that just reflection differences?
                            Object properties >
                            Receive Shadows > OFF
                            Generate Shadows > OFF
                            Vray Properties:
                            Visible in Reflections > OFF
                            Visible to GI > OFF
                            Or you could just do it in postproduction and use your glass material as a mask.
                            A.
                            www.digitaltwins.be
                              Vlado, sorry it was my fault, it only the reflection difference.
                              Jackie Teh
