region delets rest of rendering
  • region delets rest of rendering
    hi vraycrew,
    sometimes vray-region deletes the rest of the rendering.previous render in on "unchanged".rendersize was NOT changed.
    can´t reproduce this, sorry.
    ...running vray 3.10.03 on 2015designSP3
    thanks
    thomes
    This will happen if you change the number of render elements.
    Are you using the VFB lens effects by the way?
      thanks vlado, i keep it in mind. it was maybe like this
      no lens effect
        Hey Vlado,
        Is there any chance you guys can correct this? We've been banging our heads against our desks for months trying to figure out WHAT is going on with the disappearing loaded vrimgs and I stumbled across this thread. It makes sense as to why, but there are a lot of times when we need to add an extra render element to a preexisting render and don't want to rerender everything just because we added a new RE. I understand that only the region will be rendered for the new RE, but 'throwing out the baby with the bathwater' is destructive. Is there some sort of a technical limitation to keep all the pixel data in the VFB despite adding or editing REs? Thanks!
          It is complicated... but I will make a note to look into it.
            I also noticed it sometimes when you have LightSelect elements and you change light properties. Anyways, it's annoying and it would be really cool if this could be fixed
            Software:
            Windows 7 Ultimate x64 SP1
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            64GB RAM
            DxDiag
              Wow, I can count too many times this was a real killer under tight deadlines...glad someone brought it to attention
