Falloff radius in VRayEnvFog not work with inner meshes
  • Falloff radius in VRayEnvFog not work with inner meshes
    Hi
    I have one editable poly object. It's sphere inside box. I use this object as gizmo for VRayEnvFog with some "gizmo falloff radius".
    But "gizmo falloff radius" only work for box. There is no soft edges for sphere inside box.
    Why this happens? And how I can get soft edges around sphere (inside box)? Also I want to control separately inner and outer edge softness. Is this possible?
    p.s. Here is render of my problem. 3ds Max 2014 SP5 + VRay_adv_32002_max2014_x64_25860
    You can find me here:
    3dyuriki.com
    Linkedin.com/in/3dyuriki
    vimeo.com/3dyuriki
    plus.google.com/3dyuriki
    There is something buggy here - "gizmo falloff radius" is not working until "per gizmo fadeout enable" is unchecked, so please see if "per gizmo fadeout enable" is unchecked when you select your gizmo.
    Peter Matanov
    Chaos
      Yes, I know it! And it doesn't work in both cases.
      3dyuriki.com
      vimeo.com/3dyuriki
        In that case I will need your scene, because everything looks fine in my test -
        Peter Matanov
        Chaos
          Here my scene.
          3dyuriki.com
          vimeo.com/3dyuriki
            Hm how did you make the geometry ? Here is your box on the left and a poly that I made on the right, cut by VRayClipper -
            Peter Matanov
            Chaos
              I create box and sphere. Then I convert box to editable poly and attach sphere to box.
              3dyuriki.com
              vimeo.com/3dyuriki
                What effect are you trying to achieve ? A sphere shaped hole in the box ?
                Peter Matanov
                Chaos
                  yes, I want fog disappear in one place to form an empty sphere inside whole volume of fog and than it all came back (sphere must be animated to achieve smooth disappearing).
                  3dyuriki.com
                  vimeo.com/3dyuriki
                    By attaching a geometry .. you are just attaching it You are placing one volume into another, you can't expect 3ds max to know you want to create a hole Try using Boolean operations (Compound Objects).
                    Peter Matanov
                    Chaos
                      or just flip the faces of the sphere so they face inwards.. should do the same.
                        or that
                        Peter Matanov
                        Chaos
                          no, it is not the same.
                          That's it! Thank you!
                          3dyuriki.com
                          vimeo.com/3dyuriki
                            assuming the sphere is completely inside the box (ie not intersecting the sides of the box) , then flipping the faces of the internal sphere should give exactly the same result as booleaning one from the other
                              Yes, u r right! You will not believe me of course but I did it before. And it start work only after you mention this!
                              3dyuriki.com
                              vimeo.com/3dyuriki
