RT Animation Preview Render stops rendering in VRay 3.202 but not in 3.1
  • RT Animation Preview Render stops rendering in VRay 3.202 but not in 3.1
    Has anyone else had this problem?
    Hello, wxyz
    Could you send me a simplified scene with the settings that cause this problem? I couldn't reproduce it here from scratch. Mail me at margarita.stoeva@chaosgroup.com
    Thanks!
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
      Rendered yesterday a animation in production renders with RT GPU and it all worked fine for me.
      Stan
      3LP Team
        It was an OSL problem
        Originally posted by Margarita.Stoeva View Post
        Hello, wxyz
        Thanks!
          It is still a good idea to send us the scene for investigation since the issue could be caused by a bug.
            I have the same problem. It's the second time I tried it out. VRAY RT Animation Preview started to render, than rendered frame 0, switched to frame 1 and than nothing happens any more.
            I made a really simple scene with a rotating teapot and a moving camera in max 2016 and vray 3.2.
            I tried both CUDA and CPU and set the maximum render time to 0,02 seconds.
            I just see there is a error message in the max script listener:
            -- Fehler in vrayRTImageComplete(); Dateiname: C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\vrayutils.ms; Position: 74192; Zeile:: 2493
            -- Frame:
            -- reason: 0
            -- b: BitMap:\projects\frame0000.png
            -- aufgerufen in Anonymer Codeblock
            regards
            Olaf Bendfeldt
            3D-Artist
            dimension3+
              Hello!
              Could you please send us the scene if it's possible? It will be very helpful!
              I tried the setup you described and V-Ray 3.20.02 made the complete animation preview without a problem.
              Best regards
