Has anyone else had this problem?
RT Animation Preview Render stops rendering in VRay 3.202 but not in 3.1
Hello, wxyz
Could you send me a simplified scene with the settings that cause this problem? I couldn't reproduce it here from scratch. Mail me at margarita.stoeva@chaosgroup.com
Thanks!Margarita Stoeva | chaos.com
Chaos QA (V-Ray for 3ds Max)
It was an OSL problem
Thanks!
I have the same problem. It's the second time I tried it out. VRAY RT Animation Preview started to render, than rendered frame 0, switched to frame 1 and than nothing happens any more.
I made a really simple scene with a rotating teapot and a moving camera in max 2016 and vray 3.2.
I tried both CUDA and CPU and set the maximum render time to 0,02 seconds.
I just see there is a error message in the max script listener:
-- Fehler in vrayRTImageComplete(); Dateiname: C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\vrayutils.ms; Position: 74192; Zeile:: 2493
-- Frame:
-- reason: 0
-- b: BitMap:\projects\frame0000.png
-- aufgerufen in Anonymer Codeblock
regardsLast edited by dimension3plus; 07-07-2015, 12:52 AM.
