Blue Lights
  • Blue Lights
    I have lights that are orange, but rendering out blue.
    LC looks good
    Turns blue during IRR pass and renders blue. However, rendering using BF is fine.
    What is causing this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    nobody? I am on a deadline... might be a bug.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I found I had the other file I mentioned earlier with me, going to isolate the problem light I had issues with and see if I can find the problem
      Cheers,
      -dave
        thanks! BF is working, so I'll go with that for now. BF is slower for me.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Well no luck trying to figure it out, I compared settings from 2 different files and its just raising more questions than answers. I thought the thread below might shed some light on it but now Im getting weird colouring and drastic differences in light between BF and IR with just a single V-Ray light and Store with IR is not enabled :S might try to look deeper in to it tonight as its really bugging me now lol.
          http://forums.chaosgroup.com/showthr...as-Primary-now
          Cheers,
          -dave
            maybe a bug... odd the BF works and IRR doesn't.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I think it's just the prepass that is showing the wrong colors; the final render should be fine.
                I'll have to lower some settings and see if it completes accuratly
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I closed it to work on some other things, opened it back up to see, and even the pre pass looks good now. So, something is goofy.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Spoke too soon. The final render's lights were blue using IRR as the primary bounce; fine with BF.
                    It turned my tan shade material purple, too.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      i had a broken scene once recently that would render bright orange everywhere... i thought it was a self illumination but i went through the mats with a fine comb and turned them all off and fixed nothing.
                      in the end i found that rendering with BRUTE + BRUTE or IR + BRUTE fixed it but any LC 2nd pass would not work.
                      WerT
                      www.dvstudios.com.au
                        Originally posted by werticus View Post
                        i had a broken scene once recently that would render bright orange everywhere... i thought it was a self illumination but i went through the mats with a fine comb and turned them all off and fixed nothing. in the end i found that rendering with BRUTE + BRUTE or IR + BRUTE fixed it but any LC 2nd pass would not work.
                        so, it's a known bug?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Not that I know of. Can you get me a scene for it?
                            It's the same scene as my "So Slow", posted yesterday.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              As I said in the so slow thread, the problem is fixed if you desaturate the map in the translucency slot of the 2 sided mat.
                              Gavin Jeoffreys
                              Freelance 3D Generalist
