So Slow
  • So Slow
    I'm working on an interior and I will tell you what, 9hrs is the fastest time I can get. IRR + LC doesn't work (light issues) so I'm using BF + LC. I don't even have furniture in yet. The scene isn't anything special. I just finished a 4k exterior with displacement, grass, and trees in 2 hrs. I'll post the scene, but it's 900MB, if anyone is interested in looking at it.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I'd take a peek if I have time at home
    Brendan Coyle | www.brendancoyle.com
      https://files.acrobat.com/a/preview/...a-54fbdbecb57c
      I rendered with a material override, carpet displacement on/off, turned off/on lights, and render times are still high. Currently, I swapped out all lights for simple plane lights, but still 8+ hours. I am stumped!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Bobby, can you save a max 14 version of the scene file and upload it on it's own?
          pff.. 9 hrs. im doing a swimming pool interior.. its been going for 20 hrs on 17 dual xeons and its only 80% done.
          ive done almost everything i can think of to speed it up (including sending it to chaos)
          i dream of a 9 hr rendertime.
            There didn't seem to be anything out of the ordinary in your file; just lots of calculations to wade through...
              yep.. i was glad i didnt seem to have made any schoolboy errors.. ive had to add lots more detail since then, so its even slower than when you saw it.
                Bobby, thanks for the scene, looking into it now.
                  Here, is the 2014 version https://files.acrobat.com/a/preview/...6-d49df94b8af3
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Thank you!
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Having just looked at the scene briefly, to start with I would switch the mesh lights for vray disc lights.
                      And maybe up the samples on all the lights and reflections. Looks like the AA is working far to hard on this scene.
                      I will try take a better look at the scene and let you know if I would do any thing more.
                      Gavin Jeoffreys
                      Freelance 3D Generalist
                        I changed the mesh lights to simple plane lights, which didn't make a difference. Also, I played with samples on lights and reflections, but that didn't help, either. Since I can't use IRR because it's broken, I am wondering if something eternally isn't screwed up.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          To fix your IR problem, in you 2 sided mat Just desaturate the Translucency map. So it cant be an instance of the base materials map.
                          Gavin Jeoffreys
                            Worked, now I can use IRR + LC to speed things up.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Now, we are talking! It should be done in 45 minutes, baby!
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
