Hey!
I currently do some tests with the new stereoscopic panorama feature and think there is a bug in the Cube 6x1 camera type - or, i missed something
This is a simple setup with a PhysicalCamera, a VrayStereoscopic helper (eye distance; 6,5; focus method: rotation; adjust resolution) and a Cube 6x1 camera type. The attached image is rendered with a 6:1 aspect.
As you can see the camera is mirrored and the two camera sides (left/right) are swapped (see the little red/blue box in the middle). The left side of stereoscopic image is for the right eye, and the right side for the left eye.
If i change the camera type to Spherical panorama and adjust the aspect ratio/resolution everything renders fine.
Any suggestions are welcome!
Cheers!
VRay Version: 3.20.02 (nightly build: 25924)
Cheers!
