3D Displacement
  • 3D Displacement
    I know I asked before, but I can't find it with a search. I have some walls with a 3D displacement and some areas goes wonky (teething). I don't have an example, but hopefully you guys know what I mean. When I switch it to 2D, all is good. I need 3D so the corners are clean.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    bad topo in those areas? also did you check keep continuity?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      It's just a line extruded. I'll look into the keep continuity, thanks.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I´d also either tip geometry or UVs. Did you unwrap the geometry or does it use standard box mapping?
          We get this too. Try sticking a subdivide monitor on there under the displacement and UVW modifiers.
          Kind Regards,
          Richard Birket
          http://www.blinkimage.com
            ...and lower the edge length
            Kind Regards,
            Morne
              For this one, 2D is working just fine. I'll look into Railclone for the next project.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
