VRayOSLMtl Crash
  • VRayOSLMtl Crash
    1. Made a VRayOSLMtl
    2. Loaded "DigitalEmily2_OSL" shader file.
    3. Crash
    4. (╯°□°)╯︵ ┻━┻
    Using 3dsmax 2016 and Vray 3.20.02, empty scene. Sending the vraylog.txt via mail now.
    Shader file: http://gl.ict.usc.edu/Research/Digit...Emily2_OSL.zip
    Thank you for the files. We are running a test right now and when we have any information, will post here.
    Tashko Zashev | chaos.com
      There was a bug in the OSL library that caused this. It is fixed in our latest update (V-Ray 3.20.03) which should be out sometime next week. If you need it sooner than that, email our support guys at support@chaosgroup.com and ask for access to the stable builds.
        Thanks guys
          Did a test with the new V-Ray update. The error is gone, but the material is transparent. I tried with both bitmap and vrayHDRI. Am I doing something wrong, or is it still bugged ?
ID:	857976Click image for larger version
            [ATTACH=CONFIG]25335[/ATTACH][ATTACH=CONFIG]25336[/ATTACH]
            I think there is an issue with the subsurface part of the code, we are looking to it right now.
              Replace the subsurface() closure call with vray_subsurface() and it will be fine.
                Thank you
