Different buckets rendering differently with Alembic vrayproxies
  • Different buckets rendering differently with Alembic vrayproxies
    Hello, we're getting this problem:
Name:	SQ001_SH004_UNDERWATER Frame.jpg
    This is not a distributed render. All buckets are on the same CPU (although different cores). Notice it is only happening on the fish which are an Alembic vrayproxy object and not on any of the other objects in the scene. We don't think this is a map thing because it has also happened in another scene which has a shader not using any texture maps (water) but again it was an Alembic vrayproxy object.
    Any ideas?
    Could you send stripped version of the scene to: support @chaosgroup so we could investigate further.
    Also which exact V-Ray version did you use?
      We've done some more tests on this and narrowed it down to the Vray Stereo Rig. It only happens with the stereo rig and not when using a regular Max camera.
      UPDATE:
      We've got it down to this now:
      Dynamic splitting seems to be the culprit when rendering Alembic Vray proxies through the Stereo Rig. Turn Dynamic splitting off and the problem goes away.
        I couldn't reproduce the issue.
        Also I can't locate your e-mail, what was its subject?
          Sorry Zdravko, I haven't sent a file yet. We're in the process of installing the latest version of Vray (3.20.03) to see if that solves it. If not I'll attach a simple file with the issue.
          Thanks,
          Dan
            Ok. We've tried that and we've still got the problem. I'm sending a file with the subject - "Alembic Vrayproxy rending problem" to support@chaosgroup.com.
