Strange falloff on reflection which shouldn't be there
  • Strange falloff on reflection which shouldn't be there
    I got a simple scene, a floor, and a huge VRayLight (Plane) at the end of it, looking at it with a camera.
    The shader has some faked fresnel-like reflection curve as you can see here:
    Now what renders, is this:
    You notice the strange darkening right next to where it should be brightest, at the light itself.
    If I pull all maps, and the plain shader looks like this, then the effect is ALSO there oO.
    I can not understand why this happens, any pointers?
    The light is not special, just a plane, with normal, physically correct settings (well obviously 1000000 watts may be not, but its a huge wall )
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    Scene download link:
    https://www.dropbox.com/s/es0odw4vwg...floor.zip?dl=0
    Software:
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    64GB RAM
    DxDiag
      It's actually correct, reflections at the extreme angles of fresnel when you have bump/micro-facet-details get darker.
      Think of this analogy... Instead of a plane with bump imagine you had a flat ground with thousands of small buildings on, all roughly about the same height. You'd be looking across your city and you would mostly be seeing rooftops, but at the extreme far distance you would stop seeing the tops so much and instead you would see just the faces of the building facing towards you. The light is only hitting the other side of these buildings at the top of the buildings so you start to see more of the dark side instead.
      Make sense?
      Maxscript made easy....
      davewortley.wordpress.com
      Follow me here:
      facebook.com/MaxMadeEasy
      If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
        It does make sense from a fresnel standpoint. But not in this case. See the attached screenshots. In the simple shader fresnel isn't event activated. Also the ReflectionFilter elements looks unicolored, no gradients at all.
        Software:
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        64GB RAM
        DxDiag
          What you get follows directly from the way the reflection BRDFs are defined. Some of the other BRDFs (Phong, Blinn, Ward) might work better for what you want. Or you might map the reflection glossiness with a falloff map that pushes the glossiness to 1.0 at grazing angles.
            Alright, thanks for the explanation, I will propably try changing the BRDF first.
            Software:
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            64GB RAM
            DxDiag
              Do you have specular on your light enabled? I found a bunch of weirdness I was seeing in the VrayMtl was because it was rendering the reflection of a light... and then also adding a specular function on top giving you a double specular highlight. You might be seeing layer 1 of specularity in the reflectivity and then a second layer of "Specular" on top of the raytraced specularity contributing to the falloff. This is obviously physically incorrect since you're getting "correct" speculars from the reflections and then double reflections from the blinn shader but that's the default.
              Gavin Greenwalt
              im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
              Straightface Studios
                I fixed it by increasing grazing angle reflectance on GGX with Falloff Map.
                Software:
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                64GB RAM
                DxDiag
