Hey guys
Now that SP1 is out I've started to use Max 2016 in production. Today I called up a 2015 scene in 2016 that contained Vray proxy objects. Initially all of the proxies would only display as dummy cubes, much like what happens when the vrmesh file can't be found. There are no pathing issues however. If you select the dummy cubes and change the display of the proxy to another style (say preview from faces) the proxy would then display as it should. (These are "Refined Clustering" proxies).
Some proxy dummies however simply can't be selected in the viewport either by picking or window selection. The only way I could fix them was by name selecting and changing the display style as before. After that, they display as they should and are selectable. Has anyone else experienced this, and know of a fix? Is it a Bug in Max?
Cheers
Edit:
I've just found that the unselectable proxy dummies had pivot points a fair way from the object. The display issue remains however
Cheers
Edit:
