Rollouts disappear after loading saved presets
  • Rollouts disappear after loading saved presets
    I just loaded one of my saved presets and to my surprise the "Color Mapping" rollout disappeared! It was there before I loaded the preset. If I click on the empty space where the rollout was, nothing happens. Then I tried to load another one of my presets and a second rollout disappeard ("Global Switches")! I then saved the scene and loaded it to see what happens. The rollouts reappeared! Is this a bug?
    Please check the screenshot:
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Looks like a bug. Which preset feature you are using? The native 3DS Max one from the render setup main window or our V-Ray Presets from the settings panel ?
    Would it be possible to send us one of your preset files to support@chaosgroup.com
    Tashko Zashev | chaos.com
      I too, got this sometimes, using the vray presets, I think its due to the new basic/advance/expert. Normally closing and opening the window solves.
      Daniel
      Daniel Santana | Co-Founder / Technical Director
      You can do it! VFX
      Lisbon/Porto - Portugal
      http://www.ycdivfx.com
        I used my own saved presets and I loaded them through the "Settings" tab of Render Setup (F10). I will shortly send you the vray.cfg presets file.
        Aleksandar Mitov
        96GB DDR5
          Thank you Alex.
          The issue is reproduced and we are investigating further.
            We found the problem for this preset issue and fixed it for the next SP release.
