RT doesn't show correctly changed maps
  • RT doesn't show correctly changed maps
    I've noticed that when running RT (CPU or CUDA) if you right click on a map in Material Editor, select "Change Material/Map Type" and then choose "Keep old map as sub-map?", Vray doesn't correctly show the new map in the frame buffer. The new map is shown as if there's nothing plugged in it until you click some property in the map. Please check the following video to understand better what I mean:
    Vray_ChangeMapType_Bug_MP4.zip
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hi Alex,
    I just checked this problem and it seems to be fixed in the recent nightly builds. So we have to make sure this will be fixed for the next SP release.
    Tashko Zashev | chaos.com
