Bug in Multimatte isMATID
  • Bug in Multimatte isMATID
    Hi all
    To reproduce:
    1) Take a VRaymat with an opacity map and stick it on a plane, set its Material ID Channel to anything 1 or above
    2) Add a multimatte and tick isMATID with the relevant channel.
    Here's the bug:
    3) Any object behind the plane with a Material ID channel of 0, will mess up the opacity of the plane and thus also give incorrect multimatte.
    Here's 2 workarounds (WHICH IS A MAJOR PAIN BECAUSE THIS USE TO WORK FINE)
    1) All objects' materials behind the plane needs to also have some kind of Mat ID channel other than the plane and other than 0
    OR
    2) Don't use isMATID and use the object gBUffer instead
    Beauty:
    Broken isMATID (girl matID is on 1 and ground is on default 0)
    Workaround using Object G-Buffer (girl gbuffer on 1 and ground on default 0)
    Latest stable VRay build 3.20.03 (Although I did notice it in the 2.5 nightlies also - was fine in the stable 2.4 build)
    Kind Regards,
    Morne
    Hm you are right, it's not working in newer versions. We will try get it fixed for the next SP.
    Peter Matanov
    Chaos
      Thanks Peter!
      Kind Regards,
      Morne
        Any news on this?
        It's still broken in 3.40.02
        Kind Regards,
        Morne
          I will bump it up in the system.
          Peter Matanov
          Chaos
