I recently tried 3.3 on an old scene i was set up in 3.2.
When asked while opening the old scene to convert to new vray-settings i said "Yes" I get a very blueish render output.
When choosing "No" at opening the render output looks like rendered in 3.2.
I tried to figure which things had changed within render-settings, but i couldnt find any major changes. Even colormapping-settings appear the same.
When looking at the Scene-Lights they appear differently in each option. While numerical they are the same - appearance-wise they look different. So i checked if gamma-settings in max were changed, but they were not.
I attached 3 files illustrating the color difference ... and also the difference in Light appearance.
I know that vray 3.3 has introduced "updated internal spectral RGB color space" ... which is probably the cause for this stron visual difference.
Is there anywhere a switch within Vray-render-settings where i can control how Vray has to behave color-wise?
It would be quite a hassle, if for some reason one would have opted for "yes" accidently and then lights and everything will be converted and one would be unable to change back, other than opening an old file again.
