Hi all v-ray user.
I’m encounter a problem with mi GI Prepass rendering.
Symptoms:
When the prepass is calculated on single computer with 5 RN, some frame crash. 3DSMAX shutdown and restart the same frame.
The part of server log is (sorry for French part, I’m working with Win7 FR !):
The part of manager log:
The log part of Job:
The final images is looking good, no problem with GI !
If I re-render the same project, the problem appears at a different frame!
Working context:
Network configuration:
-1 computeur for rendering (Win7 x64 – max 2016 up to date, V-ray 3.30.03 up to date)
-5 Render node (Win7 x64 – max 2016 up to date, V-ray 3.30.03 up to date)
-data stocked on Virtualized Win serv 2012 R2 (+ Exterme-Z IP for our Mac network)
-Network speed 1Gb
V-Ray GI configuration:
The scène particularity:
- 1 Container as open mod to edit in place.
- 1 Container as closed mod (sources path is resolved)
- Somme textures, light, camera, animated objects.
- Somme Visibility track of object it animated (1 to 0 as stepped interpolation)
I'm not sure but,
I suppose a file writing problem or networks resources access.
An body know the problem ? ?
Symptoms:
Code:
… 2016/01/19 04:07:20 INF Block of 1 task(s) completed 2016/01/19 04:07:20 INF New task assigned: 241 2016/01/19 04:08:00 INF 3dsmax adapter : BEGIN FRAME 241; TASK 242 OF 425; (NO SAVE); 2016/01/19 04:08:00 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2016\maxadapter.adp.exe" "-o" "NewTask" "-l" "Info" "-j" "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.xml.details" "-s" "241" "-n" "1" "-a" "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.zip" "-d" "utf-8" 2016/01/19 04:08:00 ERR Task error: 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt. 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax ada⯦攻蟎璶眰‡ 2016/01/19 04:08:00 ERR 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt. 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax adapter error :㉆攻쭩璶眰‡ 2016/01/19 04:08:00 INF Application is down 2016/01/19 04:08:00 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2016\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info" 2016/01/19 04:08:00 ERR Unknown Error 2016/01/19 04:08:31 INF Receiving new job from 192.168... 2016/01/19 04:08:36 INF Job 'SQ025_VraY_PrePass_PP__15' received and ready 2016/01/19 04:08:36 INF Launching 'Autodesk 3ds Max 2016 (64-bit)' 2016/01/19 04:09:24 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max 2016\3dsmax.exe "-_pipe:2081785966" -server "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.max". 2016/01/19 04:09:24 INF [ServerMessage]ProcessStarted processId=8020 2016/01/19 04:09:24 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Ready. 2016/01/19 04:09:24 INF New task assigned: 241 2016/01/19 04:11:57 INF 3dsmax adapter : BEGIN FRAME 241; TASK 242 OF 425; (NO SAVE); 2016/01/19 04:11:57 INF 3dsmax adapter : END FRAME 241; TASK 242 OF 425; (NO SAVE); 152s; 0 faces; MEM 9415 MB; 2016/01/19 04:11:57 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Done with : Frame 241. 2016/01/19 04:11:57 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Done with task : Frame 241 to Frame 241. 2016/01/19 04:11:57 INF Block of 1 task(s) completed 2016/01/19 04:11:57 INF New task assigned: 242 …
Code:
… 2016/01/19 04:07:20 INF bstud_render_01 completed 1 task(s) 2016/01/19 04:08:00 WRN Task error from bstud_render_01 2016/01/19 04:08:00 ERR Job 'SQ025_VraY_PrePass_PP__15' (Autodesk 3ds Max 2016 (64-bit)) failed for render_01 2016/01/19 04:08:00 ERR Error message: 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt. 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax 2016/01/19 04:08:00 WRN Server bstud_render_01 flagged as failed for job 'SQ025_VraY_PrePass_PP__15' 2016/01/19 04:08:30 INF Server bstud_render_01 out of cool off period. 2016/01/19 04:08:31 INF bstud_render_01 cleared again for 'SQ025_VraY_PrePass_PP__15' (retry #1) 2016/01/19 04:08:31 INF Sending instructions for job 'SQ025_VraY_PrePass_PP__15' to render_01 2016/01/19 04:11:57 INF bstud_render_01 completed 1 task(s) …
Code:
… 2016/01/19 04:08:00 INF STA TS:000001A7 00000000 00000000 0 00000000 0000/00/00-00:00:00:0000-1957856166 0000000000000000 2016/01/19 04:08:00 INF STA TS:000001A8 00000000 00000000 0 00000000 0000/00/00-00:00:00:0000-1957856166 0000000000000000 2016/01/19 04:08:00 INF STA END:196 2016/01/19 04:08:00 ERR TS:00000241 SR: render_01 ER:3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt. 3dsmax adapter error : Le canal de communication a été fermé. : 109 3dsmax 2016/01/19 04:08:00 ERR END 2016/01/19 04:11:57 PRG TS:00000241 TM:00206293 SR:bstud_render_01 2016/01/19 04:12:44 PRG TS:00000242 TM:00046197 SR:bstud_render_01 …
Working context:
-Network speed 1Gb
I'm not sure but,
