Prepass rendering with backburner problem.
  • Prepass rendering with backburner problem.
    Hi all v-ray user.
    I’m encounter a problem with mi GI Prepass rendering.
    Symptoms:
    When the prepass is calculated on single computer with 5 RN, some frame crash. 3DSMAX shutdown and restart the same frame.
    The part of server log is (sorry for French part, I’m working with Win7 FR !):
    Code:
    2016/01/19 04:07:20 INF Block of 1 task(s) completed
    2016/01/19 04:07:20 INF New task assigned: 241
    2016/01/19 04:08:00 INF 3dsmax adapter : BEGIN FRAME 241; TASK 242 OF 425; (NO SAVE);
    2016/01/19 04:08:00 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2016\maxadapter.adp.exe" "-o" "NewTask" "-l" "Info" "-j" "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.xml.details" "-s" "241" "-n" "1" "-a" "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.zip" "-d" "utf-8"
    2016/01/19 04:08:00 ERR Task error: 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt.
    3dsmax adapter error : Le canal de communication a été fermé.  : 109
    3dsmax ada⯦攻蟎璶眰‡
    2016/01/19 04:08:00 ERR 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt.
     : 109
    3dsmax adapter error :㉆攻쭩璶眰‡
    2016/01/19 04:08:00 INF Application is down
    2016/01/19 04:08:00 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2016\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info"
    2016/01/19 04:08:00 ERR Unknown Error
    2016/01/19 04:08:31 INF Receiving new job from 192.168...
    2016/01/19 04:08:36 INF Job 'SQ025_VraY_PrePass_PP__15' received and ready
    2016/01/19 04:08:36 INF Launching 'Autodesk 3ds Max 2016 (64-bit)'
    2016/01/19 04:09:24 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max 2016\3dsmax.exe "-_pipe:2081785966"  -server "C:\Users\...\AppData\Local\backburner\ServerJob\SQ025_VraY_PrePass_PP__15.max".
    2016/01/19 04:09:24 INF [ServerMessage]ProcessStarted processId=8020
    2016/01/19 04:09:24 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Ready.
    2016/01/19 04:09:24 INF New task assigned: 241
    2016/01/19 04:11:57 INF 3dsmax adapter : BEGIN FRAME 241; TASK 242 OF 425; (NO SAVE);
    2016/01/19 04:11:57 INF 3dsmax adapter : END FRAME 241; TASK 242 OF 425; (NO SAVE); 152s; 0 faces; MEM 9415 MB;
    2016/01/19 04:11:57 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Done with : Frame 241.
    2016/01/19 04:11:57 INF 3dsmax adapter : Autodesk 3dsMax 18.6 is Done with task : Frame 241 to Frame 241.
    2016/01/19 04:11:57 INF Block of 1 task(s) completed
    2016/01/19 04:11:57 INF New task assigned: 242
    The part of manager log:
    Code:
    2016/01/19 04:07:20 INF bstud_render_01 completed 1 task(s)
    2016/01/19 04:08:00 WRN Task error from bstud_render_01
    2016/01/19 04:08:00 ERR Job 'SQ025_VraY_PrePass_PP__15' (Autodesk 3ds Max 2016 (64-bit)) failed for render_01
    2016/01/19 04:08:00 ERR Error message: 3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt.
     : 109
    3dsmax
    2016/01/19 04:08:00 WRN Server bstud_render_01 flagged as failed for job 'SQ025_VraY_PrePass_PP__15'
    2016/01/19 04:08:30 INF Server bstud_render_01 out of cool off period.
    2016/01/19 04:08:31 INF bstud_render_01 cleared again for 'SQ025_VraY_PrePass_PP__15' (retry #1)
    2016/01/19 04:08:31 INF Sending instructions for job 'SQ025_VraY_PrePass_PP__15' to render_01
    2016/01/19 04:11:57 INF bstud_render_01 completed 1 task(s)
    The log part of Job:
    Code:
    2016/01/19 04:08:00 INF STA TS:000001A7 00000000 00000000 0 00000000 0000/00/00-00:00:00:0000-1957856166 0000000000000000
    2016/01/19 04:08:00 INF STA TS:000001A8 00000000 00000000 0 00000000 0000/00/00-00:00:00:0000-1957856166 0000000000000000
    2016/01/19 04:08:00 INF STA END:196
    2016/01/19 04:08:00 ERR TS:00000241 SR: render_01 ER:3dsmax adapter error : Autodesk 3dsMax 18.6 reported error: Une exception inattendue est survenue dans le rendu en réseau, qui est en cours d'arrêt.
     : 109
    3dsmax
    2016/01/19 04:08:00 ERR END
    2016/01/19 04:11:57 PRG TS:00000241 TM:00206293 SR:bstud_render_01
    2016/01/19 04:12:44 PRG TS:00000242 TM:00046197 SR:bstud_render_01
    The final images is looking good, no problem with GI !
    If I re-render the same project, the problem appears at a different frame!
    Working context:
    Network configuration:
    -1 computeur for rendering (Win7 x64 – max 2016 up to date, V-ray 3.30.03 up to date)
    -5 Render node (Win7 x64 – max 2016 up to date, V-ray 3.30.03 up to date)
    -data stocked on Virtualized Win serv 2012 R2 (+ Exterme-Z IP for our Mac network)
    -Network speed 1Gb
    V-Ray GI configuration:
    The scène particularity:
    - 1 Container as open mod to edit in place.
    - 1 Container as closed mod (sources path is resolved)
    - Somme textures, light, camera, animated objects.
    - Somme Visibility track of object it animated (1 to 0 as stepped interpolation)
    I'm not sure but,
    I suppose a file writing problem or networks resources access.
    An body know the problem ? ?
    The error that you get unexpected code -2 might be due to the BB server started as a service. Therefore could you please stop the service and start the BB server manually.
    Also do you get the issue with a specific render nodes or it happens randomly? Moreover do you have ipv6 enabled on those machines?
      Hi Zbravko,
      Thank for your reply.
      My BB it running as normal mode, i start it manually went I'm login on the PC.
      It is not always the same RN.
      It not a IPV6 network context.
      For information, I just solved my problem!
      Now i calculate mi animation directly in each RN, BB distribute the frame calculation on my render slave PC. (No V-ray Bucket distributed rendering)
      It working good, and the Prépass issue (like dead buket !) it solved.
      And the rendering time it reduced.
      thanks'
      JB
