Problem: Making an exterior render and I'm standing quite close to my building, actually I'm inside but I don't want it to show. So I use camera clipping. But even when I put my far range at maximum my sky renders pure black. I used to have this problem with 2.4 and completely forgot about it. But it appears it's still this way with the new physical camera and vray 3.3. Am I doing something wrong? My HDRI is in a VrayDome light. When I tick of clipping it works.
Camera clipping + HDRI = black background?
Tags: None
- Likes 1
Instance the dome's HDRI into the background map slot.V-Ray Evangelist, Trainer and Freelancer
www.behance.net/rickeloy
Thank you that works, but then I have to use the horizontal rotation in the map instead of the lock to dome orientation. No problem. But if it's a bug or missing feature, it would be good that it can be solved internally.
Also, do I have to turn off the reflection/specular of the dome light then or does the background map only make the background and it has nothing to do with reflection?
Originally posted by vlado View PostIt's somewhat of a limitation; the dome light is just far away from the scene and the clipping plane is, well, clipping it. We'll have to think of a work-around for that.
My vote is for unlinking the near/far clipping. I pretty much almost never need far clipping. It's always near clipping that I use.Brendan Coyle | www.brendancoyle.com
Like Brendan, I don't think I've ever used far clipping. I've never encountered a need to separate them though so I guess it depends how much work it is.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Originally posted by vlado View PostHmm. Anyone else in favor?
Originally posted by Vizioen View PostSounds like a good idea. I've never used far clipping either, but the option might come in handy, so to seperate them, if not too much work, is a good option.Nicolas Caplat
www.intangibles.fr
