Very rough edges when using the Render Mask feature
  • Very rough edges when using the Render Mask feature
    I've been trying to use the Render Mask feature but most of the time it produces nasty rough edges. Please check the image below to see what I mean. Notice the ugly edges around the blue hull of the boat. In this image I've used Adaptive sampler, antialiasing filter VrayLanczosFilter with size of 2.0 and BF+LC for GI. Is there something I can do for the edges to appear smooth?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Can you get me some way to reproduce this? A part of the scene will be helpful. This generally works fine on simpler scenes, but maybe there is something going on.
      Sure. Please let me know where I can upload the file securely and I'll send the archived scene.
      Aleksandar Mitov
      96GB DDR5
        If you email our support guys to support@chaosgroup.com they will provide you with FTP info where you can upload the archive.
          Actually, no need to send this particular scene. I managed to figure out the exact steps to reproduce the problem which can be tested even with a simple scene. Please download the attached scene and try the following:
          1. Render the whole image with no Render Mask (don't adjust any settings)
          2. Enable Render Mask with the option Selected
          3. In the VFB enable Glare Effect from Lens Effects
          4. Select the box and render again
          The result is rough black outline around the object that appears only after the render finishes completely. So looks like this happens when Render Mask and Lens Effects are used in conjunction. I hope you can manage to reproduce it. If not, let me know and I will try to make a video of the steps.
          Aleksandar Mitov
          96GB DDR5
            We reproduced the issue and logged in our bug taking system. As soon as we get any update we will let you know.
              I get the same problem again. I'm not using glow and lens flares but I still get weird fringing/edge around the objects that are rendered with Render Mask. Any way to avoid this or is it a bug? I'm using the progressive sampler and BF+BF. Tried bucket too but still the same.
              Aleksandar Mitov
              96GB DDR5
                Any chance to send us that scene as well, it might be the same issue but it might be something else?
                  Sure, I just sent you a stripped down version at support@chaosgroup.com Everything is set, you just need to make a small region render around the slatted ceiling. I've also provided a vrimg file to load into the VFB before making the region render so you have a point of reference.
                  Let me know if you need anything from me or if any questions. Thanks for looking into it!
                  Aleksandar Mitov
                  96GB DDR5
                    Not trying to push you guys, I know you've got a lot of work around the launch of the new SP but I just wanted to know if there is any progress made on fixing the problem with using Render Mask with Lens Effects? You know, the black outlines that appear around the selected objects as seen in my first post in the thread. Is there a workaround that maybe I can use temporarily?
                    Thanks in advance!
                    Aleksandar Mitov
                    96GB DDR5
                      The developers are currently working on it. It should be fixed soon.
                        Neat!
                        Aleksandar Mitov
                        96GB DDR5
                          Hi Alex,
                          We managed to fix this bug for the next SP release.
                          Tashko Zashev | chaos.com
                            Thanks so much for looking into this and fixing it!
                            Aleksandar Mitov
                            96GB DDR5
                            • #15
                              seems like this was not fixed
                              Architectural and Product Visualization at MITVIZ
                              http://www.mitviz.com/
                              http://mitviz.blogspot.com/
                              http://www.flickr.com/photos/shawnmitford/
                              i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
