Vertical seam with VrayHDRI map as viewport background
  • Vertical seam with VrayHDRI map as viewport background
    I load HDRI maps as the viewport background from time to time for preview purposes. The problem is that I get a seam running all the way vertically if I load the HDRI image via VrayHDRI map. Strangely, this doesn't happen if I load the HDRI via the Bitmap map. The problem is only in the viewport. The seams don't appear when rendering.
    Please check the attached screenshot. Max 2016 SP3, Vray 3.30.03.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    What type of mapping is this - spherical ? I can't reproduce this... Can you share your settings and the HDRI itself ?
    Peter Matanov
    Chaos
      Yes, spherical mapping. No need to show settings and send HDRIs, I think. Everything is at default and it happens with every HDRI on 2 different workstations. Just start a new empty scene, make the viewport show the environment, choose a random equirectangular HDRI and load it in the environment slot with the VrayHDRI map in spherical mode. We're using Nitrous display mode (DX11 level) if that helps.
      Aleksandar Mitov
      96GB DDR5
        Reproduced it, thanks.
        Peter Matanov
        Chaos
          The seam is caused by the Blur option on the Coordinates rollout. VRayHDRI does not support blurred spherical environment so as a workaround you could set Blur=0.01 to remove the seam.
          V-Ray for 3ds Max developer
            Hm, I thought that enabling the tiling option in the texture should fix this... but if not, we should definitely make a note to look into it.
              Noticed the seam renders with RT, but not with advance.
                You are talking about RT GPU, right ?
                Peter Matanov
                Chaos
                  Yes RT GPU
                    Thanks for the feedback, this is a known bug which is already reported into our system.
                    We'll let you know when it is fixed.
