Normal Bump is Not Compatible With Vray Error Message
  • Normal Bump is Not Compatible With Vray Error Message
    Installing the latest update (3.30.05), I have "Normal Bump is Not Compatible With Vray" Error Message being displayed during rendering.
    Many of my older assets use this map. (because there was no additional bump slot in VrayNormal map in the earlier versions)
    Isn't Normal Bump anymore supported in Vray? Do VrayNormalMap give better results than Normal Bump?
    for my blog and tutorials:
    www.alfasmyrna.com
    It is supported on regular meshes, but the "Normal Map" texture crashes on V-Ray proxies and other V-Ray specific geometry and we can't fix this on our end. We had so many support issues related to this that we decided to print out this warning and guide users to the VRayNormalMap texture instead. We will also update the V-Ray scene converter to do this conversion.
      Hello
      I've found this piece of code a few days ago, not sure it can help (not tested yet):
      try(destroydialog ::vrnRoll) catch()
      rollout vrnRoll "NormalMap Convertor" width:168 height:30
      button btn "NormalMap to VrayNormalMap"
      fn getMaterial arr = for i in arr where isKindOf i VRayMtl collect i
      on btn pressed do
      for g in geometry where g.mat != undefined and (ins = getClassInstances Normal_Bump target:g.mat).count != 0 do
      for m in ins where (isKindOf m.Normal_map Bitmaptex) do
      NMap = VRayNormalMap namem.name) normal_mapm.Normal_map)
      if (arr = getMaterial (refs.dependents m.Normal_map)).count > 0 do (for n in arr do n.texmap_bump = NMap)
      createDialog vrnRoll style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
      Nicolas Caplat
      www.intangibles.fr
        I perfectly understand. So it is time to convert these maps to VrayNormal. Thanks for the clarification.
        Originally posted by NicoC View Post
        Hello
        Many thanks
        www.alfasmyrna.com
          Thanks to Pixela and Vlado I have this problem too, more on trees which I've created with SpeedTree!
          and I have a question from both of you guys and I'll be so pleased if you give me an answer, The answer is which normal map creator program does work better with V-ray?
          Thanks in advanced
          sigpic
          www.saeedamiri.com
            I have been posting about this for a couple months. They happen on every project and the error will repeat thousands of times.
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              Hello
              It didnt work on my scene.
              www.alfasmyrna.com
                You know, it doesn't work for all the normal errors but does for most.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I couldnt run the script, it gives error.
                  www.alfasmyrna.com
                    This worked for me
                    http://www.scriptspot.com/3ds-max/sc...rt-normal-maps
                      Thank you
                      www.alfasmyrna.com
                        Some of the errors can be fixed my converting the bump map to a V-Ray Normal Map.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
