Strange artifacts when rendering to texture
  • Strange artifacts when rendering to texture
    Hi community,
    I'm getting weird artifacts when rendering to texture.
    Can someone take a look and comment if you know how we can fix this problem.
    Tried this by rendering to VrayCompleteMap or Vray TotalLighting.
    This is from a simple test scene. We have it also with rectangular objects of a simple villa.
    And the simple scene
    bake test HQ.zip
    And the villa textures
ID:	883824Click image for larger version
    We checked the model and there are no double faces.
    The sphere scene is rendered with IR+LC and the villa with brute force.
    Vray 3.30.03
    3ds max 2016 sp3
    Windows 7 x64
    It looks like those artifacts comes from the ambient occlusion GI effect. I'll try with the latest build now and see if the issue still occurs.
    Tashko Zashev | chaos.com
      Thank you Tashko.
      I tried also without GI. It is different but some weird results remain.
      I'm awaiting for the results of your testing.
      Kind regards
      Correction. Switching the Ambient Occlusion off solves the problem but the baked result is flatter.
      Any news on the newest build?
        I just completed one render test using the latest official 3.30.05 build (it's actually the same for the latest nightly build) and here are the results :
Name:	2016-03-23 13_06_07}.png
        All artifacts remain for Ambient occlusion enabled so this might be a bug. So I'm going to forward your scene to our developers team for a further investigation.
        Can you show me? I don't see that effect in my screenshot.
          Hi Tashko,
          What i meant is that the result is flatter textures because of the lack of ambient occlusion. Not what I intended but not a vray problem by itself.
          Is your render without ambient occlusion on?
          Anyway if its a bug weird nobody reported on it before. Or people aren't using ambient occlusion for texture baking.
          Kind regards
            Originally posted by vraypixel View Post
            Hi Tashko,
            Kind regards
            Yes, the top part is without AO.
            We will post here when we have any feedback from our developers. Thank you.
              My clients have recently reported the same problem. It has not been remedied in V-Ray 7.
              I understand that not many people use GI AO, but Chaos should either fix the problem or display a warning that GI AO is not supported during baking.​
              OakCorp Japan - Yuji Yamauchi
              oakcorp.net
              v-ray.jp
                Originally posted by flat View Post
                My clients have recently reported the same problem. It has not been remedied in V-Ray 7. I understand that not many people use GI AO, but Chaos should either fix the problem or display a warning that GI AO is not supported during baking.​
                FYI, I've added your report to the log (internal bug-tracker id: VMAX-4702).
