Specular with plane light
  • Specular with plane light
    Hello,
    i got a simple plane light, and a black material on a flat object with Hglossiness = 0.8, and Rglossiness = 1.0.
    i should get some "fake" specular on that material.
    on rendering, the specular is very grainy and not smooth at all...
    any ideas ?
    thanks !
    try increase plane light subdivion, see whether it help or not
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
      It's really difficult to provide an answer to a question which basically misses all substantial information.
      VRay Version?
      Render Settings?
      Light Settings?
      Screenshot?
      Software:
      Windows 7 Ultimate x64 SP1
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      Intel Core i7-4930K @ 3.40 GHz
      NVIDIA GeForce GTX 780 (4096MB RAM)
      64GB RAM
      DxDiag
        yeah indeed, was a bit speedy on this one..
        here is a sample jpg/max
        working on max2016/3.30.04
        I'm on adaptive 1/4 settings. Of course, if i go to 1/24 its get better. But the whole idea of the Hgloss was to "fake" specular, so it's seems a bit strange to push all the settings.
        https://dl.dropboxusercontent.com/u/...1/specular.zip
          Increase your MSR so that it will use more subdivs for your light and material samples
          Gavin Jeoffreys
          Freelance 3D Generalist
            tried it, it doesn't really affect the Hgloss noise.
            only setting the adaptive image samples max to 16 or 24 helped
              Hgloss is not to fake spec, it is the specular component. It still needs light subdivs as far as I know.
              If you want your images samples as low as 1/4 make your MSR 256. On your example this will render it very quick, about a second for me.
              Just remember that MSR and image samples will need to vary depending on what your scene is like.
              Gavin Jeoffreys
                ok thanks
                will try this out !
                  only disadvantage of putting a high MSR value, is that on complex scenes with lot's of materials and reflections, it will boost all the samples on the image, and therefore rendering time will be much higher.
                  usually on my scenes a MSR value of 16 is quite enough
                    You may also resolve the noise via Image Sampler settings or via Light Subdivions(Use Local Subdivs must be turned on) or by combining all three of them:
ID:	860300Click image for larger version
