Spawner - macroscript "vrayShowVFB" Error
  • Spawner - macroscript "vrayShowVFB" Error
    I have a problem with my spawner. It doesn't render and sometimes it also crashes.
    As you can see in the attached window, the spawner opens a macroscript "vrayShowVFB" ...
    Why am I encountering this error and what to do about it?
    Thanks in advance.
    www.bpositive.dk
    Could you make sure that you are using identical V-Ray versions on both machines? Also could you send/attach vraylog.txt files from the problematic render node machine and from the machine where the DR job is submitted?
    Do you get a stable 3ds max dummy in the task bar when starting the VRay Spawner? Also have you run BB job between the machines before? Do you start V-Ray Spawner manually or a s a service?
      Hi Zdravko
      Thank you for your response.
      After opening 3ds max on the spawner machine, I saw that it had problems opening a script called "__temp6688" under the "appdata" folder. I have deleted it and now everything works again.
      www.bpositive.dk
        Thant is interesting, does the same issue appears if you re-install V-Ray?
