Spawner - macroscript "vrayShowVFB" Error
Could you make sure that you are using identical V-Ray versions on both machines? Also could you send/attach vraylog.txt files from the problematic render node machine and from the machine where the DR job is submitted?
Do you get a stable 3ds max dummy in the task bar when starting the VRay Spawner? Also have you run BB job between the machines before? Do you start V-Ray Spawner manually or a s a service?
Hi Zdravko
Thank you for your response.
After opening 3ds max on the spawner machine, I saw that it had problems opening a script called "__temp6688" under the "appdata" folder. I have deleted it and now everything works again.
