VRMat linux paths vs windows paths
  • VRMat linux paths vs windows paths
    So since the textures used by vrmats doesnt show up in asset tracker, I can use a text editor to modify the paths inside the vrmat.
    BUT
    Seems the vrmat likes to see linux paths // instead of windows paths \\ (or at least the ones I'm dealing with)
    I need to map to a mapped drive, so then if I edit the vrmat to show to P:\ for example, will DR pick up the textures and will the vrmat still work?
    Kind Regards,
    Morne
    I think so; at least I don't see a reason why it shouldn't.
      Any way of getting it to show in asset tracker in the future? (and thus changing it from asset tracker)
      Kind Regards,
      Morne
        We need to do some changes in the code to allow this.
          I would greatly appreciate it
          Kind Regards,
          Morne
            I will make a note about it, but I'm not sure when it can be implemented. If we implemented support for relative texture paths in .vrmat files, would that work better?
              As long as DR can pick it up easily.
              I also now noticed something weird, some of the vrmats textures "automatically" picked up the "correct" path, while others show the old UNC path. Very weird.
              Kind Regards,
              Morne
                Please! We SERIOUSLY need this
                These VRmats and the export import from other app, truncating of file names etc, Seriously... It would just be so much better in max if we can just please convert the vrmat to a normal VRayMtl
                Kind Regards,
                Morne
                  Which other application is that?
                  It's not always possible to convert .vrmat files to Max materials - there are some texture nodes that are not present in Max. There might be other ways for us to do that in the future though.
                    These came from Rhino
                    Kind Regards,
                    Morne
                      I'm on another one similar to this.
                      It's almost completely useless to have vrmats in Max as you can't mass edit them in any way. I'm now manaully editing each vrmat (xml) to change paths. Not fun when there's 246 of them.
                      Also, you have to BROWSE for each vrmat, you can't just drag and drop it into a VRayVRmatMtl, which makes it even longer to work with these. So far I also haven't found a way to display the diffuse in the viewport, so difficult to tell which objects have the correct material or not.
                      Extremely frustrating
                      I still think something that can convert the vrmats from Rhino to Max VRayMtls would be best. Even if it is just best effort close as possible with the 1:1 features, and ignore the rest.
                      It's xml files, can't be that hard to write a script to convert to VRayMtl.
                      @Lele, Up for for some coding?
                      Kind Regards,
                      Morne
