Ies
  • Ies
    Is there any issues with IES lights in the latest MAX or V-Ray? Several jobs and I haven't been able to get them to work.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I find them pretty much useless unless you actually add an IES file into them
    Kind Regards,
    Morne
      I was using an IES file. I ended up using RT, encreasing the brightness until I could see it, and ran with it. The intensity is so high I would have never had gueeses it had to be that bright.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        If you have problems with VRayIES lights, please share the files or even better - the whole setups so we can check them. Also, please note that there are many not so decent IES profiles circulating the internet.
        Peter Matanov
        Chaos
          Is there a reliable source with IES files that work fine with Vray? I often have the problem that I need to manually edit the values of the IES in notepad because it has negative or flipped values.
