DR Spawner not resetting - low RAM
  • DR Spawner not resetting - low RAM
    Our render farm is used to render both stills and animations through Backburner.
    The queue is managed so a node is only rendering 1 job at a time.
    Lately we are experiencing a new issue with the DR spawner:
    Essentially, after a DR render completes, that required approx 28GB ram, the spawner does not reset on nodes with only 24GB ram. It keeps "vray_server_scene.max" open and all of the ram it was using. All other nodes we have (32GB-64GB ram installed) reset back to "vraydummy2014.max" as expected. The problem is that when these nodes then try to render a frame from an animation, it keeps unloading geometry (because there is no ram available) and predicts a 350+ hour render for a 20 minute frame.
    Environment:
    Windows 7 throughout
    Max design 2014
    VRay 3.30.04
    Dynamic memory limit set to -4000 via maxscript.
    Any ideas?
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    Generally its best not to use those machines which haven't got enough memory to handle the scenes. Or you can write a script which force spawner restart on render end for the specific machines.
