Hello VRay Support,
Our studio have recently purchased CG-Source's floor generator. It is a plug-in and generates geometry through an object/space modifier.
https://cg-source.com/floorgenerator.php
It seems to work on our local machines, but does not work with DR... ie, the geometry generated becomes non-existent. We have narrowed down the problem to DR, as tests using Backburner gives consistent results as local renders. We contacted CG-Source to try to investigate. They have done their own test with DR and it works fine for them. I was wondering if you could shed some light on what maybe causing our render nodes not to recognize this plug-in object/space modifier when using DR.
Thank you for your help,
Julie
Julie
