VRayDenoiser complete black unless I uncheck the hardware acceleration
  • VRayDenoiser complete black unless I uncheck the hardware acceleration
    I have an issue with VRay 3.4 denoiser. I got all black VRayDenoiser render element. After trying to figure out what might be the problems, I turn off hardware acceleration option, and I my denoised image came out.
    My hardware: HP ZBook 15 G2 Mobile Workstation
    Rgds,
    Chen
    Hey Chen, good that you have found what is the cause of the problem. I think those workstation can be configured with different GPUs. V-Ray comes with a tool named ocldeviceselect.exe. Can you run it and see what devices it finds ? Also, does this happen with every scene ? Can you check what are the messages in the V-Ray log in 3ds Max when this happens ? Also, what is your video driver version ?
    Thanks,
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Hi Blago
      I have the same thing (Fujitsu H370 mobile workstation, Quadro K2100M gpu), was going to post about it tomorrow morning, but will just add to this thread instead.
      Nvidia driver is 362.13
      oclselect attached
Name:	Ocldevice select.JPG
      Will check the log and let you know if it gives any info.
      Log says Denoising complete in 12.08 s.
      0 errors 0 warnings.
      Gavin Jeoffreys
      Freelance 3D Generalist
        Thanks,
        Best,
        Blago.
        Yes, it happen with all scenes. Here are screenshots of OpenCl devices and drivers info:
ID:	862302Click image for larger version
ID:	862303Click image for larger version
          I found a GPU with the same core as the K1100M and K2100M and tried to reproduce it here. It wasn't a Quadro series though, so the driver was a bit different.
          Unfortunately, it seems to work on our machines.
          We can try the following:
          1. Add the V-Ray denoiser render element and form its advanced denoiser parameters choose Mode->"Only save render elements".
          2. Render any scene and save it as .vrimg from the VFB.
          3. Navigate to the tools directory (default is C:\Program Files\Chaos Group\V-Ray\3dsmax 2016 for x64\tools).
          4. Open a command window there and run the following denoising commands:
          "vdenoise -inputFile=pathToSavedImage.vrimg -useGpu=0"
          "vdenoise -inputFile=pathToSavedImage.vrimg -useGpu=1"
          "vdenoise -inputFile=pathToSavedImage.vrimg -useGpu=1 -oclquery=intel"
          "vdenoise -inputFile=pathToSavedImage.vrimg -useGpu=1 -oclquery=nvidia"
          I will need the log from the command window and also I will need to know if the denoised result was correct.
          If you don't want to deal with this, we can arrange team viewer session, so we can log in and check what is going on.
          V-Ray fan.
          RTX ON
            Hi Blago,
            What information you need for the team viewer? (I never use it before)
              We need the ID and the password in order to connect to your machine.
              Please download(link bellow) and install(or just run) Teamviewer, then send the credentials to support@chaosgroup.com and include svetlozar.draganov@chaosgroup.com in CC.
              http://www.teamviewer.com/en/
              Looking forward to hearing from you.
                Also having this issue on one of the workstation only for now. Mine works fine, one of my staff has to uncheck gpu for the denoiser to show something else than black.
                The workstation are extremely similar but he updated the driver this morning when I didn't for a month or more.
                  Hi Blago
                  Ran the tests in command.
                  1st,3rd and last all gave denoised result. 2nd gave black screen.
                  Attached is the command log.
                  Gavin Jeoffreys
                    Originally posted by Raven View Post
                    Hi Blago Ran the tests in command. 1st,3rd and last all gave denoised result. 2nd gave black screen. Attached is the command log. Thanks
                    Okay, so it seems to happens in nvidia GPUs only. Now I only have to manage to reproduce . I hope the team viewer session will help.
                    Btw, I don't see the log. Is it something at my end or you forgot to attach them ? edit: I see them now.
                    Best,
                    Blago.
                    V-Ray fan.
                    RTX ON
                      980 TI black here, too.
                      Bobby Parker
                      www.bobby-parker.com
                      e-mail: info@bobby-parker.com
                      phone: 2188206812
                      My current hardware setup:
                      • Ryzen 9 5900x CPU
                      • 128gb Vengeance RGB Pro RAM
                      • NVIDIA GeForce RTX 4090 X2
                      • ​Windows 11 Pro
                        Not sure if I should chime in here as this is related to the Maya version but I also get an instant crash on my 2013 Macbook Pro (NVIDIA GeForce GT 750M, 10.11.4) if I don't uncheck Hardware Acceleration. Should I post this on the Maya side?
                        Ben
                          Ben
                          Can you try downloading again from the website and re-installing ? The first version uploaded had this issue, but it should be fixed already ..
                          Sorry for that,
                          Best,
                          Blago.
                          V-Ray fan.
                          RTX ON
                            Bobby, what is your driver version ? Does it work without the hardware acceleration ?
                            Hi Blago
                            Many thanks for the test !
                            You have run 4 tests. Is it the case that the 1st and the 3rd and 4th worked, and the 2nd didn't ? Or the 2nd and the 4th didn't ?
                            Thanks for the feedback guys. We hope to find the cause of this as soon as possible.
                            V-Ray fan.
                            RTX ON
                              Bobby, what is your driver version ? Does it work without the hardware acceleration ? Many thanks for the test ! You have run 4 tests. Is it the case that the 1st and the 3rd and 4th worked, and the 2nd didn't ? Or the 2nd and the 4th didn't ? Thanks for the feedback guys. We hope to find the cause of this as soon as possible.
                              I'm not sure of the driver version, but I know it is the latest. I can check in about an hour. I didn't see anywhere to disable the hardware acceleration.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
