I've noticed that when I add in the Denoiser element, it adds in an additional dozen elements that show up in the VFB but don't show up in the Render Elements list. Is that supposed to happen?
Excessive Render Elements 3.40.01
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2023.3 Update
V-Ray GPU 6 Update 1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
I find it strange as well. I'm not sure why there isn't just the one.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
If you select the middle option on the bottom drop box (generate render elements: depending on denoising type) it reduces the file size of the resulting EXR by about half. (at least with all other options on default, eg single pass rgb mode))
It would be nice if we could select which channels of the EXR are saved out regardless. That way we could use the full blown per channel noise mode, and save an EXR that was not more than twice normal size.Last edited by werticus; 10-06-2016, 12:54 AM.WerT
www.dvstudios.com.au
Originally posted by werticus View PostIt would be nice if we could select which channels of the EXR are saved out regardless. That way we could use the full blown per channel noise mode, and save an EXR that was not more than twice normal size.
VladoI only act like I know everything, Rogers.
