Excessive Render Elements 3.40.01
  • Excessive Render Elements 3.40.01
    I've noticed that when I add in the Denoiser element, it adds in an additional dozen elements that show up in the VFB but don't show up in the Render Elements list. Is that supposed to happen?
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    I find it strange as well. I'm not sure why there isn't just the one.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      They are used to denoise better the output.
      Gil Guminski
      cynaptek.com
        They are needed by the denoiser.
          If you select the middle option on the bottom drop box (generate render elements: depending on denoising type) it reduces the file size of the resulting EXR by about half. (at least with all other options on default, eg single pass rgb mode))
          It would be nice if we could select which channels of the EXR are saved out regardless. That way we could use the full blown per channel noise mode, and save an EXR that was not more than twice normal size.
          WerT
          www.dvstudios.com.au
            Yes, will think of something...
